1 - 7 of 7 Posts
AKA StubbornGreek
I've created a Query that populates several fields of a particular table. Now, I want it to filter the results and return only those rows with one particular field populated.
In other words, say the 5th field of the Query is blank, I would want it to exclude this record, and every other record that has a blank 5th field.
Thanks.
Provide an example of that data?
Subquery with a where clause using IsNull?
Originally Posted by RonindeBeatrice
"select field,field2,field3,field4,field5 from table where field5 <> '' "
you might have to use ... "where (field5 <> '' and field5 is not null)"
A catch all: "where len(trim(field5)) > 0"
AKA StubbornGreek
Excellent, thank you.
Now, one more question (sorry sort of noobish with access '07). If I remember correctly, there should be an Administer or Administrator button on the Database Tools portion of the Ribbon, no (its not there now)? If not, how does one set permissions for different users (i.e. User 1 gets forms xyz and zyx while User 2 gets forms abc and cba)?
EDIT: Never mind, I just remembered that was for '03 formats - I figured out the rest. Thanks again,
1 - 7 of 7 Posts
