Yea true...In b4 a shyster posts.
Gray Mole was probably still around then..He built one for a friend of mine, but has since disappeared.I remember in 2010 a few people use to build them
Die electric grease in socket art putty and electrical tape lol. I have a dice pot but want sub ambient dailyHere you go....
Something to note is to super-insulate your mobo and shoot dielectric grease into the socket. Yikes. Anything can go wrong. If it's AMD, maybe put chip in and vasoline or LET all around socket. Cannot be above IHS, though.
Obviously that's an SS unit I linked. Cascades are like unicorns these days. Maybe learn to build your own?Die electric grease in socket art putty and electrical tape lol. I have a dice pot but want sub ambient daily. I would build one but want a cascade unit honestly.
i ran die electric grease on a 955BE -40c for 6 months straight, i ended up getting pin rot, lost a few grounding pins on the cpu (still worked fine)Die electric grease in socket art putty and electrical tape lol. I have a dice pot but want sub ambient daily. I would build one but want a cascade unit honestly.
Lmao bong cooler holding -20 to -50c idles and loads around -20 to 0c. Nahnah go cooler and build a big ol bong cooler
On a 2066 cpu? Imma have to get creative and make that block fitEK actually just released one, probably better than anyone could make. If you have 350$, your should go for it. EK-QuantumX Delta TEC - Copper + Nickel
Just think of how easy it will to be making a slushy with some green water!Lmao bong cooler holding -20 to -50c idles and loads around -20 to 0c. Nah
This is very true what you said sooner or later you will run into condensation. I still have a Cooler Express SS phase changer kicking around the house that I once used for 24/7 use. No matter how well you insulate the cpu socket and the surrounding area you will still manage to run into issues sooner or later like I did. Great for benching no so great for a 24/7 setupI used to back in the day. Vapo XE, Prometeia r404a/Cap tube modded, Vapo LS, Mach II GT and custom r404a/r507a/Delta fans units. You will run into condensation issues sooner or later though. Great for 15 hour long 3DMark benching sessions but you just can't insulate them well enough for 24/7 applications. Still worth a try but that's just me.
