I went and ordered this since it's only $279.99 after rebate and I am taking a chance on it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026
There is no reviews anywhere on newegg and no reviews on google. The only thing I found out is that the cooler looks a little bit different and if you look at specifications it looks to be a little bit smaller by about an inch than the 100352-2L model, the one everyone bought and recommends.
I'm hoping it OC's well and I will let you guys know as soon as I get to test it.
It should arrive by tomorrow or Thursday.
MAX STABLE OC 1130mhz gpu 1550vram on stock voltage no tweaks only +20% powercontrol
EDIT: for newcomers to this thread this is the results so far.
The 3 images represent 3 different OC results starting from low to high.
Last picture is 1140mhz 1565 0vram stock voltage temperature 69celcius at 53% fan. I hit maximum for my GPU core. After 1130 i get flickering or driver stopped responding. It might get fixed if I would raise voltage to 1.30v, but I don't need anymore power I value silent too much. Max for VRAM is at 1555 over drive stops at 1575.
Pretty good GPU. Gamble was successful
For anyone still on the fence about this GPU go ahead and purchase it. Cooler is outstanding That last picture 1140mhz gpu at 53% fan speed it's maximum 69celcius
VERY QUIET. Also voltage is unlocked btw. My asic quality is 42.5% not sure if it matters just so u know. AFAIK this board is not reference. It's about 1/2 inch shorter. So full cover waterblocks won't fit on it or maybe not cover everything.
