1 - 4 of 4 Posts
Some call me... Bifford
I just got this board in and want to get an XP-120. Thermalright says I can use it if I don't use the first mem slot. Normally I would use 1-3. However it appears that with this board using 3-4 is fine. Can anyone back this up before I order the XP-120?
Dimm1 and Dimm3 are considered Channel A by MSI.
Dimm2 and Dimm4 are considered Channel B.
So using Dimm3 and Dimm4 would be considered "dual channel"
I'm lookin at the manual to make sure.
yes, running on dimm 1 and dimm 2 would be dual channel and running dimm 3 and dimm 4 would be dual channel as well
youve got it xavier
Reactions: BFRD
1 - 4 of 4 Posts
