1 - 6 of 6 Posts
Hehe crotched fan.
I don't know about this blue orb, but I'm sure alot of people would recommend the Big Typhoon.
What socket do you have?
that is pretty much the same thing as the Zalman 7700, but likely worse, if you like that design get the zalman but if you want the best performance then get a big typhoon
In the olden days the Gold Orb was the king of coolers. Thermaltake now has revived it with a cheap knock off...They can get an a for effort, but not much else..
Originally Posted by dex100
...but if you want the best performance then get a big typhoon
or a zalman 9500. i have had very good results from mine. i love it
The blue orb is a poor cooler, the cooper base is hollow so it may not be what you want, I would go for the zalman fatality cooler since its the same size.
1 - 6 of 6 Posts
