I have a Rampage III Extreme and a 3ware 9750-4i installed on PCI-E 2.0 Slot 4. I have two WD 600GB Vrap's hooked up and both are classified as Single Drives. I have FSX installed on one and all my FSX photo scenery installed on the other. Everything is working fine.
Everytime I start SpeedFan I get two 3ware10K Event ID 11 error codes in Event Viewer. Everytime I start Aida64 I get the same 3ware10K Event ID 11 error codes, but instead of 2 it is 12. This happens each and everytime I start either of these. I can start HWM Pro, Asus AI Suite, Asus PC Probe II, CPU-Z and RealTemp and these error codes never show up. I think that it may have something to do with the 9750-4i being on the PCI-E bus and SpeedFan and Aida64 reading ROG data off the PCI-E bus, but it is just a hunch. HWM Pro reads the same data as Aida64. SpeedFan reads the same data as Aida64, just not as much.
Attached are a couple of screenshots of Event Viewer. Even though the two HD's are hooked to Port1 and Port2 on the 9750-4i I still get the Port0 error codes with nothing hooked to Port0.
Now my question, can anyone with a 9750-4i download and run Speedfan and see if they get these error codes? I have contacted LSI Tech Support and their response after three weeks of emails back and forth is they are not really sure what is wrong and they will not try and duplicate the problem since my motherboard is not a server board.
Like I said, everything seems to be running fine, now I am just really curious if it can be duplicated.
SpeedFan is a free download, here is a link.
http://www.almico.com/sfdownload.php
Of course, if you have Aida64 already please try that.
