1 - 6 of 6 Posts
Ever since I got my use on the HD3850 & HD5850, I have been using ATI Tray Tools. I never use the Catalyst Control Center (CCC) as I have been just downloading the "drivers only w/out CCC" package. I have been using ATT to change graphic settings, and it has been working great.
However, ATT has not been updated in almost half a year, and now that 10.8 is out, I wonder if there's anything better than ATT right now for Radeon graphics cards?
What do you guys use?
semi-legit
MSI Afterburner is the software of choice for most now.
You can bypass the locked BIOS by editing a config file in said program if your Sapphire PCB is reference.
Can also flash BIOS to another unlocked one (or even 5870 BIOS) if it is as well.
Hmm... I've used MSI Afterburner before, but it was mostly for overclocking. I didn't know it had 3D modifying settings.... are you sure that it does?
I was looking over at the features again from the Afterburner's website, but couldn't find anything. I originally wanted a program that could change more of the Direct3D & OpenGL graphical settings such as antialiasing, mipmap details, texture settings, etc.
1 - 6 of 6 Posts
