12900k is not flat, especially after being inside the socket. If anything asetek coolers have an advantage over flat coolers due to the convex waterblock contact.I've been using a few different AIOs on 12900K, and now transitioning to water. In my case, the ALF 2 out-performed both Z73 and Ryujin II 360s by about 5 degrees...flatter contact probably for one thing.
480? is that arctic 420mm or 480mm radiator? If 360 to 420 arctic how much of a performance gain did you experience?Yep, which is why I did the washer mod and later installed TG socket frame (minus mod) before using ALF 2 360 and then 480. The bending damage has been done and needs a lapping, but to me, wasted further effort on a mediocre SP82. Have another daily so moving on to loop in prep for 13900K or good 12900ks if opportunity arises.
Right...420mm. Went directly to push/pull with 360 so can't make straight comparison. Otherwise push/pull 360 and 420 were about the same. My comparison is made strictly by how hot a rogue #7 P core was getting after numerous 10min CB23 runs with same settings and many remounts on both.480? is that arctic 420mm or 480mm radiator? If 360 to 420 arctic how much of a performance gain did you experience?
I may buy a p500a + arctic 420mm and do a push pull with arctic p14 fans. Corsair h170i is an option too buy does cost in the region 1.7.-1.9x more. Waiting for 13th gen before I make any decisions.Right...420mm. Went directly to push/pull with 360 so can't make straight comparison. Otherwise push/pull 360 and 420 were about the same. My comparison is made strictly by how hot a rogue #7 P core was getting after numerous 10min CB23 runs with same settings and many remounts on both.
Good case choice for AIO imo. Coincidentally have been using a p500a performance (non-rgb) with ADL and loving it. P/P for 420 is super tight for bottom pull fan, top 2 pull no issue. 3 x140s won't fit between mounting frame and front mesh, 3 x 120s will.I may buy a p500a + arctic 420mm and do a push pull with arctic p14 fans. Corsair h170i is an option too buy does cost in the region 1.7.-1.9x more. Waiting for 13th gen before I make any decisions.
I believe you can do a mod to enable you to mount 3 140s in the front. There is a video on youtube somewhere. Worst case scenario 5 fans still goodGood case choice for AIO imo. Coincidentally have been using a p500a performance (non-rgb) with ADL and loving it. P/P for 420 is super tight for bottom pull fan, top 2 pull no issue. 3 x140s won't fit between mounting frame and front mesh, 3 x 120s will.
