Anyway to not get the 511
568 13
I have just been getting the 511 over and over and over again. i want a diff one. 3k a day sucks.
1 - 14 of 14 Posts
Originally Posted by ProjecT TimeZ
Here you go.
While this increases your chance to get the better WUs, it does not completely eliminate the bad ones...
the only way is to delete the files and start over, which if you ask me, is much more work than is needed. Its like gambling, luck of the draw.
Discussion Starter · #6 ·
ture, Oh well. thanks guys +reps
Originally Posted by oulzac
I don't mind the 511's, but is there an explanation anywhere that explains what each is, and why the 511's take the longest to complete?
At present the 511 ones are provide actual progress, while the 353's simply just test to make sure the GPU client is working properly and not providing misinformation.
then it seems like the best are 511s if you really care about curing diseases!
1 - 14 of 14 Posts
