Anyway to recover a RAW File system?
958 15
My WD 1TB My Book Home Edition suddenly gone to a "RAW" File system.
Is there anyway for me to recover it back to FAT32 format without loosing any data?
Please any input would be nice.
1 - 16 of 16 Posts
Questionnaire galore!
How about something free?
Discussion Starter · #6 ·
Originally Posted by Domino;14201612
google is your friend bra.
I would prefer OCN Giving me ideas and programs.
So the hard drive went bad and the computer can't even recognize the partition or file type?
Might want do a chkdsk... otherwise the data is probably gone without some type of professional recovery software.
if chkdsk does work and recover the partition, backup all the data immediately and run the WD lifeguard diagnostic tool to see if the drive did go bad.
Discussion Starter · #9 ·
The External HDD was going along smoothly, one day i booted my lappy up(where it's always connected) then i tried opening it, then it say that the drive is not formatted.
Tried to plug it into these...
Windows XP using USB
Windows Vista using USB
Windows 7 uisng USB
Windows 7 using firewire.
I just found this
One of the guys there said to use this.
I need all my data back, and as much as possible, not buy a new HDD for now.
Iconoclast
There are numerous recovery apps that will let you scan and recover data from the drive, many of them free.
The program I prefer is commercial and isn't supported anymore, but something like TestDisk (http://www.cgsecurity.org/wiki/TestDisk) should do what you need.
Discussion Starter · #11 ·
Can i just recover the partition, and not buy a new HDD for a couple of months with that?
Discussion Starter · #12 ·
Also the file system before was FAT32, if that helps
Discussion Starter · #13 ·
Also how exactly will i use TestDisk?
Discussion Starter · #15 ·
1 - 16 of 16 Posts
