1 - 3 of 3 Posts
Any way to tweak the AOD multiplier?
Mine shows maxed but my board can do more.
Used to be able to edit it in Turbo Core and then it would give more after I closed that window.
Disabling TC in BIOS makes that disappear, though.
No there's not, you should not overclock using AMD OverDrive. While it's a nice program, it's still a hybrid-software method that doesn't load your overclock till you get to the OS. But does interface with the BIOS.
Still it can cause some stability issues.
I prefer BIOS to begin with, but it's a lot easier bumping the multi while in an OS to push the limit of what a certain voltage will provide you. A lot of times will just get errors in super pi for instabilities instead of entire BSoD's.
1 - 3 of 3 Posts
