1 - 3 of 3 Posts
Just installed MySQL, and now the Apache service won't start.
I have:
extension_dir="C:/PHP/ext"
extension=php_mysql.dll
set in the php.ini file.
Apache will only start after I comment out the "extension=php_mysql.dll" line.
What's wrong?
EDIT: Figured it out. The entry was duplicated; for some reason a bunch of extensions were enabled by default at the end of my PHP file. Every reference I've looked at said they'd be under "Dynamic Extensions" commented out by default.
I have:
What's wrong?
It is possible the install may have automatically enabled them for you.
Yes, I noticed that too when I was setting up PHP with MySQL. They have the actual directory extension commented out in favor of declarations at the bottom that include every possible extension. I don't understand the point of it actually, but maybe it's so that people don't have to manually edit the .ini file
1 - 3 of 3 Posts
