What of those blocks would be best for watercooling my system. It will be a CPU and GPU in the same loop, so less restrictive is good.
The ncie thing about the TDX is that it is ready to mount on a 1366 and it is cheaper. The GTZ will cost $80 and the Fuzion V2 will cost $80 also because of the stupid brackets (are they required for an i7?)
Originally Posted by H3||scr3am
I'd say that the FuZion is your best bet for performance / dollar... and don't forget the nozzle kit, and use the quad split
does the nozzle kit and quad core splitter really make a difference? These things just add up in cost so fast.
Basically, what everyone else said.. they're about the same overall. I chose the GTZ for myself, though. Just seemed to be a better fit for me. (and it looks great!)
Definitely the GTZ or FuZion. I'd say the FuZion's a little better.
The GTZ and FuZion are pretty close.... GTZ usually wins by a tiny bit. However, the GTZ fittings are spaced futher apart making it a LOT easier to clamp.
Overclock.net
