Apogee XT on 775
1109 Views 12 Replies 6 Participants Last post by  olympiawa
I've been reading that the new Apogee XT beats the heatkiller 3.0, and that it is specifically optimized for the i7/i5 processors. I'm about to get my feet wet and am decided on a waterblock, and I'm curious as to wether this new Apogee is now the best waterblock for my q6600
Any ideas?
1 - 13 of 13 Posts
The Apogee™ XT is shipped with a Universal hold-down plate and retention mechanism compatible with all Intel® Core™ desktop processors: sockets LGA775, 1156, and 1366. All Apogee™ XT waterblocks shipped to retail channels after November 1st 2009 include the motherboard back-plates for sockets LGA1366 (Core™ i7) and 1156 (Core™ i5 and i7). The socket 775 motherboard back-plate is not included with the block and is mailed to users free of charge upon request.
from: http://www.swiftnets.com/products/Apogee-xt.asp
Right, I wasn't questioning compatibility, but performance. Will it perform as well on the older quad core processors as it will on the i7s?
I can't imagine why not. i7s are high-wattage CPUs OC'd as are q6600s. There's nothing particularly different between the two in a thermal-dynamic sense that I can think of. Does a TRUE or Megahalems do worse on a Q6600 vs an i7?
Only thing I can think of that'd adversely affect performance was if the LGA775 mounting would be of a poorer design than the LGA1156/1366 design.
edit: actually Swiftech says it's optimized for all LGA intel CPUs, if you want to follow the advertising.
* Mechanical Design
Mechanical design of the copper base plate is optimized for Intel® socket LGA 771, 775, 1156 and 1366. The topographically mapped mating surface has been considerably enhanced to yield dominating results with Intel® socket LGA 1156 and 1366 processors. Other types of processors such as AMD® socket F, AM2, AM3 and 940 may also benefit from the enhanced contact area.
I would recommend the HK 3.0 because there are a lot of defects on the XT. Trust me I have one and Swiftech wouldn't replace it.
Here is the thread to prove it http://www.overclock.net/water-cooli...ontrol-10.html
Lite. Its the exact same block with a delrin top instead of a copper one. performance is identical, all differences in testing are to be attributed to errors in measurements.
You don't per se need a backplate to go with the HK on a 775 platform. However, a backplate will help in applying even pressure against the face of the CPU.
This may be a stupid question, but I already have a back plate for my xigmatek air cooler now...do I need to get one specifically for the HK?
unless the threads differ, i'd say no. i'm no WCer tho.
I used the back plate from my old Zalman HS for my XT. BTW I did see a few defects but I'm still happy with the temps. However, I'm disapointed in Swiftech's QC, really hope it improves. The XT is a nice block and $20 cheaper than the HK with "better" performance. I say "better" because its like 1C.
1 - 13 of 13 Posts
