This is an A+ rated panel, meaning that it has absolutely no dead pixels and no back light bleeding. With the korean monitors you're rolling the dice on whether you'll get a good panel (some can be just as good as this or the Dell U2711) or you can get a really bad one with uneven backlighting and dead pixels. If you're interested then PM me and maybe we can work something out.
I don't think the catleap monitor includes a camera, speakers, several USB out and an elegant aluminum unibody shell
Some Korean sellers will offer to check for dead pixels for you for like an additional $20-30. So getting one without dead pixels/flaws is entirely possibleOriginally Posted by Shozzking
You're right, the Korean IPS monitors offer nothing in common with an ACD other than sharing an LG IPS panel.
It's under 6 months old and I still have the original box and all accessories.
Remember, I'll take reasonable offers (lowballs will be ignored).
You're absolutely right. There are 2 different models of this display, the cinema display and the thunderbolt display. They are both clearly labelled on the box. The thunderbolt display will not work with pc's or older non-thunderbolt macs. This is the version with mini-displayport (took me ages to find a new one).
