Applying thermal compound best & easiest way ?
655 4
I will be installing my hyper 212 tomorrow and have never applied any compound always used stock HSF. Iv'e been reading and so far its been suggested a horizontal line or a small blob in the middle of the cpu the size of a grain of rice? Are these the correct practices?
What is the best way? I don't want to have to remount would like to get it working the first time.
1 - 5 of 5 Posts
I do it according to AS5 instructions:
http://www.arcticsilver.com/pdf/appi..._quad_wcap.pdf
Yep, it really depends on what type of TIM you are using. The stickier stuff I usually spread out a bit before mounting the HSF. The thinner stuff I do a glob in the middle of the CPU and let the pressure do the work.
1 - 5 of 5 Posts
