1 - 3 of 3 Posts
Here are more detailed specs... only what's in the list should be appraisaled<br />
<br />
CPU: 2.4 Ghz Northwood<br />
Motherboard: VIA w/ intergrated sound<br />
RAM: 512GB DDR400<br />
GPU: 6200 w/ 256MB<br />
Moniter: Sony 22" CRT<br />
Sound: intergrated<br />
PSU: Antec 350W<br />
Operating System: Windows XP Pro<br />
Hard drive: 80GB IDE<br />
DVD drive<br />
CD burner/writer/rewriter
Well , it's not a gaming rig(very weak gpu) but if it has a PCI-e slot you can upgrade that.<br />
You could also buy another 512megs of ram, for a huge performance enhance.<br />
That's all.....<br />
<a href="http://http://www.newegg.com/Product/Product.asp?Item=N82E16814143054" target="_blank">gpu</a><br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820145026" target="_blank">ram</a>
bump
1 - 3 of 3 Posts
