1 - 4 of 4 Posts
I am looking to put away some money for school and put a bit of money into my X79 rig, and frankly I just don't use my Z77 rig much at all anymore except as an occasional media PC (I know, it's kinda sad :'( ).
I would PREFER to sell the entire thing as one system, but if I get enough buyers for the individual components, I would be willing to part out; again, selling as a system is preferred....
This post is going from memory, I have a list of everything in it at home so I will check it this evening when I get home and add anything I may have forgotten.
This rig was built in February, all parts were bought from Newegg or at local Micro Center, with MOST of the water cooling bits coming from PPC's or Aqua Tuning.
Many of the parts have been replaced quite recently, and other parts added, including: all system memory (2-3 weeks old), tubing changed to Primochill Advanced Clear about a month ago, the original Swiftech Maelstrom res was switched for a Koolance dual-DDC single bay res + a BP 250mL res about a month and a half ago, the second MCP35X has less than 100hrs through it, the UT60 is only ~2mo old, the 680 Lightning was a "refund" for one of my burned out 7970 Lightnings and came BNIB directly from MSI via overnight shipping and is no more than 3 months old, and well you get the idea.
Anyway, onto the components.....
MAIN COMPONENTS
- Self-Binned Intel Core i7 3770K aka best out of 5 chips bought locally from Micro Center, LOW-VOLTAGE CHIP!!!! (de-lidded using the "hammer" method, no damage to PCB or IHS, about 3 mo ago; Prolimatech PK-1 used between the Die and IHS, and between IHS and block) **This chip is a very good OC'ing 3770K, especially since de-lidded; it's never required more than approximately 1.415v to exceed 5.0Ghz and temps in P95 Blend at that speed are between 74C and 83C with a 20C ambient**
- Gigabyte GA-Z77X-UP7 Motherboard in pristine condition (having used the ROG Z77 boards, and despite preferring the Asus BIOS, this is without a doubt THE Ivy Bridge motherboard to have if you want to do serious overclocking; chances are that you will exhaust your skills before the board even starts to sweat, I know I did!)
- 1 OR 2 2x4GB Kits of G.Skill Trident X DDR3-2400 9-11-11-31 memory (without question one of my absolute favorite memory kits for benching, but these are so new that they've only ever run at their XMP settings, although both can do so at ~1.605v or so; also, all four DIMM's are double-sided HYK0 as best I can tell, they're 100% certainly double-sided but I haven't taken the heatsinks off to check markings on IC's; these are MINT!)
- 1x MSI GeForce GTX 680 Lightning with fully unlocked voltage control and power limit (that's right, truly unlocked voltage! it came from MSI with a slightly different LN2 BIOS than what I'm used to, but it works better, feels more refined)
- 1x Samsung 840Pro 128GB Solid State Drive used as OS drive (still at full health, minimal amounts of writes to it since it was put into service, and benches exactly what it should)
- LG Blu-Ray Burner (can't remember the model number, but at the time of purchase it was the top model available...6 months ago)
- OCZ Z-Series 1000W 80+Gold Modular Power Supply (all voltages are well within limits, stability is good, it's a solid workhorse of a unit and still sells for $180 or more new! I have all modular cables)
- Bluetooth/WiFi mPCI-e Card (can't remember the brand/model off the top of my head, but it was the nicest one I could find locally; excellent range!)
- NZXT Switch 810 (Gunmetal, has the "upgraded" top to allow 3x140 rads without drilling; condition of the case is maybe 7-7.5/10)
- 3x Cougar 120/140mm PWM Case Fans (2x Front Intake, 1x Rear fan; radiator fans are listed separately, below)
- NZXT Individually-Sleeved Black Extensions for PCIe Power, 24pin ATX power, and 4pin/8pin EPS Power
- DemciFlex Dust Filters to replace the "meh" stock ones both up front for the 2x front intake fans and up top for the three "outside" top-rad fans
- Have a G.Skill Trident X RAM Fan if it's wanted, came with the memory (I don't use it because, well, 1: it doesn't need it, and 2: the LED's don't match at all)
- Scythe Kama Bay Fan Controller with 6 Channels and LCD Temperature and RPM Readout (has been extremely reliable, doesn't even get hot when under long periods of loading)
*Have a large collection of other fans, including some Noctua, Cooler Master, NZXT (painted orange), and a bunch of others that could be switched for some of the Cougar fans, although I would have to charge a bit more for some like the Noctua which have never been used and are literally more than 2x the price of the Cougars
**NOTE: Because of the amount of personal and important data on them; however, if not having a mechanical drive is truly a deal killer, I could always toss in a 2-3yr old 320GB WD Blue or HGST Deskstar for a few bucks??
WATER COOLING COMPONENTS
- XSPC Raystorm CPU Block with original sleeved LED's
*OPTIONAL: Can substitute a BNIB XSPC Raystorm Full-Copper Edition for extra
- XSPC Aluminum Hold-Down Plate for the Raystorm (turns the block from "okay" to "incredibly good", too bad it's not included and they charge so much for them)
- Aquacomputer G680Ltg AquagraFX Full-Coverage LIMITED EDITION GPU Block (literally the LAST ONE sold by Aquatuning; I am 150% impressed with it, in fact it is so nice and well made/effective that I am considering going with AC Kryographics "window" blocks next time I change cards, "breaking" my long running Heatkiller loyalty!)
- Koolance RP-401X2 Single 5.25" Reservoir for 2x DDC pumps (practically brand new condition, and one of the best-made reservoirs I've ever seen)
- Bitspower Multi-Z Tank 250 with POM End-Caps
- 1 OR 2x Swiftech MCP35X pumps installed in the Koolance res (I would like to see a price for it with one or with both; one is 6mo old, the other is brand new; both work extremely well)
- Swiftech dual PWM Wire for MCP35X2 style use
- 1x BRAND NEW/NEVER USED Noise-Blocker 80x15mm Fan with all accessories (bought to use on pump heatsink, but as the MCP35X2-Heatsink doesn't work when using the Koolance res, and because there is quite a bit of airflow already keeping the pumps below 40C, it's never been needed; far and away the nicest/best and quietest fan you can get for direct pump cooling!!! I've used them all, and these are well worth the $20+)
- XSPC EX360 Radiator in the top with the exterior, not the fins, painted orange to match the board (excellent slim radiators, if not fighting for top place in its weight class
- 6x Cougar 120mm Fans in Push-Pull (fans are all less than 3 months old)
- Alphacool UT60 240 Radiator (current king of the 60mm-thick or less radiators, less than a month and a half old)
- 4x Cougar 120mm Fans in Push-Pull (fans are slightly newer than the radiator)
- Bitspower Rotary Angled Fittings, Extensions, Couplers, and 1/2x3/4 Compression Fittings (a very kind, awesome, amazing friend gave me a handful of his fittings as I was short
- Monsoon 1/2x3/4 Compression Fittings in matching matte black (again, very kind friend!)
- Misc other fittings (all said and done, at least $250 in fittings due to some tricky turns)
There is a bunch I KNOW that I am forgetting (sorry, I took a bad spill the other day and cracked a few ribs, broke + cracked + bruised the cartilage connecting my ribs to my sternum, and got a "6 out of 10" concussion; been having some nominaphasia and other memory difficulties aside from the pretty awful pain; at least I now have a sweet 2" scar an inch below my hairline on the right side of my forehead... not.... :/ ).
Just to reiterate, this is less than 9 months old, has never seen sub-zero cooling or anything like that, and many of the parts are only a month or two old. This is pretty much as nice as you can go with Z77 and a single GPU setup, in terms of components, and while I'd love to keep it, I know that it just won't get used like it deserves... Therefore, I think it's time to let it go to a better home.
Here are a few quick and dirty pics (sorry, it's been crazy dusty lately! the whole rig will be cleaned extremely thoroughly!!!) that I took with my phone just to give a basic idea of the rig.
(NOTE: the tubing is NOT hazed or plasticized in any way, these pics were just taken while flushing out the last of the Mayhem's Gigabyte Orange Pastel dye that was run for a few months; currently it has nothing but Distilled Water and PT-Nuke PHN)
Photos are in chronological order, so the first ones are how it was when it was first built into the state its in now, the last photos are exactly how it is now....
IF YOU WANT TO SEE SOME VERY "ROUGH" PERFORMANCE FIGURES, PLEASE CHECK MY HWBOT PROFILE AND SUBMISSIONS!!! Those were all done with very quick and dirty overclocks, I just haven't had the time to really work on getting my ranking back lately. Also, those were done with 4x4GB Samsung "Wonder RAM" at just 1866 or 2000 with loose timings and prior to de-lidding.
****If you are interested in the now-very-rare and very-expensive Samsung WondeRAM, 4x4GB of locally purchased sticks that are brimming with potential, and which have only really seen gentle use; I can't guarantee that I will part with them, it depends on what happens with my girlfriend's PC, but don't hesitate to ask!
$260 - Self-Binned Intel Core i7 3770K aka best out of 5 chips bought locally from Micro Center, LOW-VOLTAGE CHIP!!!! (de-lidded using the "hammer" method, no damage to PCB or IHS, about 3 mo ago; Prolimatech PK-1 used between the Die and IHS, and between IHS and block) **This chip is a very good OC'ing 3770K, especially since de-lidded; it's never required more than approximately 1.415v to exceed 5.0Ghz and temps in P95 Blend at that speed are between 74C and 83C with a 20C ambient**
$300 - Gigabyte GA-Z77X-UP7 Motherboard in pristine condition (having used the ROG Z77 boards, and despite preferring the Asus BIOS, this is without a doubt THE Ivy Bridge motherboard to have if you want to do serious overclocking; chances are that you will exhaust your skills before the board even starts to sweat, I know I did!)
$85 each pair - 1 OR 2 2x4GB Kits of G.Skill Trident X DDR3-2400 9-11-11-31 memory (without question one of my absolute favorite memory kits for benching, but these are so new that they've only ever run at their XMP settings, although both can do so at ~1.605v or so; also, all four DIMM's are double-sided HYK0 as best I can tell, they're 100% certainly double-sided but I haven't taken the heatsinks off to check markings on IC's; these are MINT!)
$350- 1x MSI GeForce GTX 680 Lightning with fully unlocked voltage control and power limit (that's right, truly unlocked voltage! it came from MSI with a slightly different LN2 BIOS than what I'm used to, but it works better, feels more refined)
$100 - 1x Samsung 840Pro 128GB Solid State Drive used as OS drive (still at full health, minimal amounts of writes to it since it was put into service, and benches exactly what it should)
$40 - LG Blu-Ray Burner (can't remember the model number, but at the time of purchase it was the top model available...6 months ago)
$120 - OCZ Z-Series 1000W 80+Gold Modular Power Supply (all voltages are well within limits, stability is good, it's a solid workhorse of a unit and still sells for $180 or more new! I have all modular cables)
$100 - NZXT Switch 810 (Gunmetal, has the "upgraded" top to allow 3x140 rads without drilling; condition of the case is maybe 7-7.5/10)
$12 each for 120mm, $14 for 140mm- 3x Cougar 120/140mm PWM Case Fans (2x Front Intake, 1x Rear fan; radiator fans are listed separately, below)
$40 - XSPC Raystorm CPU Block with original sleeved LED's
$90 - Aquacomputer G680Ltg AquagraFX Full-Coverage LIMITED EDITION GPU Block (literally the LAST ONE sold by Aquatuning; I am 150% impressed with it, in fact it is so nice and well made/effective that I am considering going with AC Kryographics "window" blocks next time I change cards, "breaking" my long running Heatkiller loyalty!)
$80 - Koolance RP-401X2 Single 5.25" Reservoir for 2x DDC pumps (practically brand new condition, and one of the best-made reservoirs I've ever seen)
$30 - Bitspower Multi-Z Tank 250 with POM End-Caps
$65 each - 1 OR 2x Swiftech MCP35X pumps installed in the Koolance res (I would like to see a price for it with one or with both; one is 6mo old, the other is brand new; both work extremely well)
$45 - XSPC EX360 Radiator in the top with the exterior, not the fins, painted orange to match the board (excellent slim radiators, if not fighting for top place in its weight class
$10 each - 6x Cougar 120mm Fans in Push-Pull (fans are all less than 3 months old)
$55 - Alphacool UT60 240 Radiator (current king of the 60mm-thick or less radiators, less than a month and a half old)
$10 each - 4x Cougar 120mm Fans in Push-Pull (fans are slightly newer than the radiator)
Thanks!
Discussion Starter #4
bump?
1 - 4 of 4 Posts
