1 - 4 of 4 Posts
With 20GB HDD
One controller
VGA cable
A/V cable
Power brick
Headset
Thanks!
I also have the warranty sticker, it's not currently ON the 360, but I can put it back on. It's also fresh back from MS, if that matters.
Originally Posted by gablain View Post
how loud is the fan ? Has it benn oppened ? Since how long do you use it ? Does it overheat ? Any signs of rrod ?
The fan?? Idk, normal?
It's been opened, but like I said, I took the warranty sticker off properly, I can put it back on and no one would ever be able to tell it's been opened.
It doesn't overheat, like I said, it's fresh back from RMA.
All of this was said in my OP... except the loud fan part, which I don't really get.
1 - 4 of 4 Posts
