Try to sell or put up as freebie
  • Put up as freebie
    Votes: 1 100.0%
  • Put up a FS thread
    Votes: 0 0.0%
1 - 8 of 8 Posts
I have 4 sticks of laptop ram (2 sticks are DDR2-5300 and 2 are DDR2-6400) all 4 are 1gb sticks, and 3 sticks of regular ram, 1 stick of DDR2-6400 2gb, and 2 sticks of DDR-3200 both 1gb. I was just wondering if they are worth anything at all? Otherwise I will just put them up for freebies. Thanks guys.
I would normally just put up the freebie but right now funds are ridiculously tight.
They don't make DDR2 or DDR frequencies that high man, unless I'm terribly wrong. You're reading the wrong part of the label.
Edit: You're better off keeping them for yourself of giving them as freebies. You might get about $5 or so at the most (per stick)
yea I meant PC-6400 and PC-5300 etc. Or DDR2-800 etc....
Discussion Starter #5
Originally Posted by wiretap View Post
That would be PC2-5300 and PC2-6400. That signifies the MB/s bandwidth of the memory. They would be DDR2-800 and DDR2-667 respectively.
That's what I said, I am throwing these appraisals together inbetween caring for my 7 week old sorry. I guess I just assumed you guys knew what I meant and there are pictures.
Ddr2 is eol and has value but the sizes are a bit small. Maybe $10-15 a set
1 - 8 of 8 Posts
