Originally Posted by YiffyGriffy There's no set specification for vcore based on a given clock speed, it just takes tests. Run Prime95, and keep adding vcore until you can pass Prime95 torture test for at least a couple hours. |
Originally Posted by YiffyGriffy I've never heard of anyone running a vcore higher than 1.9 - 2 volts. Keep it senseable, take baby steps. Really the most you should have to run would be 1.9 volts |
Originally Posted by Ludaz Mkay. Im running 220x11 w/ Vcore at 1.725 and Dram still at 2.7, and I still cant get past even 1 test on Prime 95. Would increasing the Dram help? Also, could I get some Vcores that other people using the XP-M 2600 have? Thanks. |
