1 - 2 of 2 Posts
Random Eventer
Setup:
A10-6800k APU
Asus F2A55-M MotherBoard
2x8gb G.skill 1866mhz RAM
Windows 10 64-bit OS
Radeon 7770 2gb GPU
https://www.3dmark.com/fs/15199227
I used the setup without the GPU and rank Firestrike here
Whenever I put the 7770 into the system I'm not able to get the computer to display an output (plugging a display into the motherboard, GPU, and even both at the same time)
Looking for suggestions on what I could do to see what is causing this problem or fix this problem.
Random Eventer
Discussion Starter #2 (Edited)
Without having the GPU installed the desktop doesn't have any problems displaying via HDMI or DVI
When I install the GPU I'm not able to get the motherboard or GPU to display
Showing what I think could be related to the display problems, but not sure on what options should be choosen.
IGFX Multi-Monitor can be [Enabled or [Disabled]
Primary Video Device can be [PCIE] or [Integrated]
Integrated Graphics can be [Auto] or [Force]
If [Force] is selected I can choose how much memory I want the APU's GPU can use.
1 - 2 of 2 Posts
