1 - 8 of 8 Posts
i just noticed that the flow meter in my aquabay m1 is not spinning. i investigated it, no tubings where bent, pump is running, everything in my loop is ok. but then i saw that there are some small material (i have no idea what it is) inside the flow meter that is blocking the spinning thingy. my question is, is it ok if i leave this not spinning for the mean time? my temps are ok and not going up. i would flush out all the water and take the mateials out but i don't have any coolant at the moment. is it ok if i leave it till i get some coolants? will it affect anything?
Originally Posted by Mootsfox View Post
It shouldn't. As long as the water is still flowing. You might want to find out want exactly it is though.
how do i know if the water is still flowing? i know man, i have no idea what is, its too damn small, i can barely see, but i know its the causing the meter not to spin.
Unfortunately the Tt Flow meter has not had a good service life... a friend of mine who sells Tt products has had these returned... mainly due to their 6.5mm tubing size..it would be best to remove it and just keep on eye on your CPU temps...
Pujo, Lose that T-Take thing...EDIT:...
Originally Posted by pujo
yeah dude, waiting for the coolant
Good deal Buddy....
1 - 8 of 8 Posts
