1 - 19 of 19 Posts
Petrolhead
Many thanks @MartPwnS.
I will update it later.
Update also, hoping this might fix the problems with disappearing 10G nic.
Attaching the backup image in case someone is not happy with the fw update or just wants to revert to the original fw.
@MartPwnS thank you for the info
Driver updated to 2.1.21 (from 2.1.20) just fine, but firmware 3.1.109 (currently at 3.1.100) doesn't recognize my adapter, any ideas why? (EDIT: using ASUS ROG AREION 10G here)
On the readme.txt file is a small list of devices.
Supported devices
Motherboards with 10GbE/5GbE
  ASRock Fatal1ty X299 Professional Gaming i9 XE
  ASRock Fatal1ty X399 Professional Gaming
  ASRock Fatal1ty X370 Professional Gaming
  ASRock Fatal1ty Z370 Professional Gaming i7
  ASRock X470 Taichi Ultimate
  ASRock Z390 Taichi Ultimate
  ASRock Fatal1ty Z270 Professional Gaming i7
  ASRock Z270 SuperCarrier
NIC, TB3 dongles, and TB3 docking stations
  Aquantia AQtion 10G Pro NIC
  Aquantia AQtion 10G Gaming NIC
  Aquantia AQtion 5G Pro NIC
  Aquantia AQtion SFP+ NIC
  Gigabyte GC-AQC107
  Promise SANLink3 N1
  QNAP QXG-10G1T
  QNA-T310G1S
  QNA-T310G1T
  Sonnet Solo10G SFP+ Thunderbolt 3
  Sonnet Technologies Solo 10G Thunderbolt 3
My luck is that x370 Professional Gaming and X470 Taichi Ultimate are supported.
Oh yeah, thanks zhadoom, did not notice that.
Just checked the previous version 3.1.100 and it supports a few more devices, strange:
Supported devices
  ASUS ROG X299 RAMPAGE VI EXTREME
  ASUS PRIME X299-DELUX II
  ASUS ROG Z390 MAXIMUS XI EXTREME
  ASUS XG-C100C 10G Network Adapter
  Gigabyte GC-AQC107
  Z2 G4 Wotkstation
  Z2 Small Form Factor G4 Workstation
  ThinkStation P320
  ThinkStation P330
  ThinkStation P520
  ThinkStation P520c
  ThinkStation P720
  ThinkStation P920
  Promise SANLink3 N1
  QNAP QXG-10G1T
  QNA-T310G1S
  QNA-T310G1T
Yes, thank you xgiovio, that worked!
For my ASUS ROG AREION 10G it was:
<pciid vid="1d6a" did="d107" sdid="872E" svid="1043" />
EDIT: wanted to register there and thank the author of that post, but I still don't have "insufficient privileges to reply" on their forums, even though I confirmed my account yesterday... ¯\_(ツ)_/¯
EDIT2: wow, and now they just deleted my account, great forums, thanks www.snbforums.com! XD
@Deepcuts : I think you've missed a few posts since your last one ;)
The Marvell website is the culprit for the confusion. The date of the files are of the moment of download not the creation date of the version. I posted this driver/firmware 3.1.109 in 04/04/2020.
Yeah, imagine how happy I was when the date changed and I noticed that. For me it updates every day I enter, so basically shows the current date. No idea why they would do that.
My bad.
Have some issues with my 10G nic going missing from time to time and with every new firmware update I hype myself, thinking this could be the update that fixes my problems.
Most likely a Gigabyte motherboard problem, but one can only hope.
Hello,
what is the difference between 3.1.109 versions and 4.2.32 version ?
I found only version 3.1.109 on marvell official website
I have an Asus XG-C100C 10G with AQC-107 chipset (PCIexpress card)
Thanks
I don't get it, how does that work and why the number downgrade?
EDIT: also, these don't work now for my ASUS ROG AREION 10G card, even after editing the updatedata.xml file, like the last time, with:
Help?
1 - 19 of 19 Posts
