1 - 2 of 2 Posts
Have you tried measuring the distance from the first ram slot to the centre of the socket and comparing it to the depth of the archon? From the centre of the Archon's base to the front there are 26.5mm. Add another 25mm from the fan, and you get a rough 50mm of minimum distance between the socket (well, LGA) centre and the first ram slot.
Hope that it helps.
1 - 2 of 2 Posts
