1 - 8 of 8 Posts
HD Tune: WDC WD1600AAJS-00L7A0 Benchmark
Transfer Rate Minimum : 30.7 MB/sec
Transfer Rate Maximum : 106.1 MB/sec
Transfer Rate Average : 84.5 MB/sec
Access Time : 15.9 ms
Burst Rate : 132.9 MB/sec
CPU Usage : -1.0%
Access time looks a little slow, but don't know much about that actual drive.
That looks normal.
Originally Posted by overclocker23578
normal looks slow
Average 84 MB/s for a WD Blue? That is perfectly normal.
Note that this is not the F3 in OP's sig.
Senior Overclocker
That can be "fixed"
Op, take a look at my thread
I used to get 16ms access time .. manually setting the AAM value to 254 dropped my access time to ~12ms
This was on WD hdds... not sure if it works on Samsungs ... but I assume it does
My bad, I looked at your sig HDD ...
It should work. I see that its a WD
1 - 8 of 8 Posts
