1 - 3 of 3 Posts
Currently swapping out my rasa for a raystorm. I remember getting the back plate out and on for maintence last time was a pain. Can I just keep the backplate from the rasa installed for the raystorm? They look the same but making sure
It'll be a non-issue. Generally speaking, you can use pretty much any backplate you want so long as the screws for the mounting system are the same width/thread that the backplate accepts. Even if the screws aren't the same on the Raystorm, you could just use the screws from the Rasa. However, the backplate and screws look identical to the ones on the Rasa, so long story short, you're good.
1 - 3 of 3 Posts
