1 - 7 of 7 Posts
· Banned
I was searching around ebay and I came upon these. They are 130CFM at 48dBa. which is kinda loud but I figure a fan controller would take care of the noise. Also does anyone know how I can make my own fan controller? I was thinking about just hooking up 12v lead with a electric dimmer.(like a house light kind). Im not sure if it would work.
- Atomic
· SNERP!!!
Those fans would be great. I'm running 86.5 CFM and I'm happy as a clam with my temps.
I would go to radio shack for the fan control part. I know you will have to deal with morons, but you will eventually get the part you seek...I hate radio shack.
· Banned
So Im not the only one? haha.
Quick question. I just got my heater core from autozone, how does this thing work? there are no pipes going through the fins. Did I order the wrong thing? Its autozone part number 398219. I was sure I bought the right thing.
· Premium Member
You should start this question in your own thread !
It would use flat section tubes to allow the coolant flow. Each of the tubes will be seperated into smaller flow paths.
cheers
· SNERP!!!
I just did a search with that number on the autozone website and it didn't display a pic. Take a picture of it if you can or find the right one and link it.
*edit* I'll just link one to you. http://www.dangerdenstore.com/produc...&cat=14&page=1
· Banned
cheers
This IS my thread, look at who started it.....
Yeah thats it, just with out the barbs. The input and output pipes are like really messy though. Ill take a couple pics and show you...
-Atomic
1 - 7 of 7 Posts
