Your mobo has a 3+1 phase design with no vrm heatsinks. That would be your only concern. Apart from that the cpu voltage is more than fine. Keep temps low. The two things which cause degradation are high temps and high voltages. The higher you raise your voltage, the lower your temps need to be.
