up the voltage, flash it with nvflash/nibitor, make a custom BIOS for it pump the voltage up, and link the core and shaders in a 1:2.5 ratio then follow the straps... also make sure you're on drivers that are 180.2 or later, as CUDA 1.1 helps a bunch. also set the priority of the core to high, to try and get the most out of it...
Overclock.net
