Idle temps mean nothing, you should check your load temps as that is what you need to make sure are safe. The 9700 is a sub par cooler but if your load temps are in check then you have nothing to worry about. Run Prime95 and check temps with Coretemp and get back to us.
In reality if you check the Intel CPU forum for what the max temps are for the 8400 you would be better off. However if they determine you are looking a little high them come back and we can get set you on the right track for a better cooling setup.
Best of luck!
EDIT: Just did a quick look anything under 60c during full load is stellar even overclocked.
Best of luck!
