1 - 4 of 4 Posts
So I built a new gaming PC a few weeks ago, haven't really been able to test my PC up until now. I downloaded the Unreal Tournament Alpha, after 10-20minutes of playing I get these temps.
Is this normal?
You might need to add a couple fans/improve airflow in your case, everything is getting hot, so I would start there.
We need more information before we can give suggestions.
First, I really would't use Speccy as temp monitoring, it is a nice program overall, but I've never gotten reliable temps from it. I'd check your temps with something like HWmonitor first, and post back here.
Other than that, we would need your build info. Every piece, fans and case included. You should probably also fill out your rig in the rigbuilder here on OCN, so it shows up in your sig (like mine and Raventhegod)
1 - 4 of 4 Posts
