Artic silver 5
3414 Views 82 Replies 28 Participants Last post by  ArchCorsair
should i be worried? people kept talking about how it's conductive, would this electrocute my i7 or something?
1 - 20 of 83 Posts
no, it won't
as long as you have it just on the top of the CPU, and don't get any into the socket or onto the motherboard, you'll be fine...there's nothing to conduct between the CPU and the heatsink, anyway
AS5 is thermally conductive and not electrically conductive. It is slightly capacitive as well.
nah relax
I think it is somewhat electrically conductive (silver is a metal, after all), but really, it's nothing to worry about. As long as you aren't smearing the AS5 all over the contacts, just keeping it to the contact face, you should be fine.
But you're not putting liquid silver on your CPU, are you?
You'll be fine - even if you smeared the pins on your CPU in AS5 it wouldn't short out.
From the way it's advertised you'd think that AS5 was liquid silver.
But I'll say again, I use AS5 on all of my CPUs, never had an issue. It works great, especially if you give it a week or two to cure.
If you're really worried about it, try the Noctua NT-H1 Thermal Compound.
http://www.mikhailtech.com/Reviews/N...Compound/page1
Outperforms AC5 and OCZ Freeze compounds, isn't conductive, and has ZERO burn in time.
Just be sure to not do anything dumb like apply it to the socket or the bottom of the CPU and you'll be fine
IC Diamond works much better than AS5. I'm not sure but I believe it is better or at least on par with the noctua NT-H1
use the only the size of rice grain. one of my first builds i globed it on there then when i took it apart and it got in the socket and killed the machine. it was the socket 4xx something amd, thankfully nothing expensive at the time.
Edit: you only need a small dab of the stuff, don't over do it.
What about removing existing thermal compound from a new heatsink (Arctic Freeze 7 Pro in this case, with Arctic MX compound, or something like that) and replacing it with Arctic Silver.
Good/bad idea?
How long is the "burn-in" time for AS5?
IC7 Diamond is muuuuch better than the noctua.
Supposedly 200 hours.
OP: Don't be worried. Many people use AS5 for a long time with no issues, myself included.
Don't use it on GPUs, or memory chips though. As DuckieHo said, it's thermally conductive, and slightly capacitive, so it can hold a small electrical charge and can potentially bridge electrical connections, shorting out the component.
The best Thermal Paste is only like 3-4C better than AS5 anyway, but they're generally much more expensive, and harder to spread. If you don't mind all this, then they're worth it, but generally I'd say something like OCZ Freeze or MX-2 is better than IC7 Diamond even if just because of ease of application and price.
uhh, i'm pretty sure there've been a few threads about people who've spilt AS5 in their socket by accident and not noticed, and the socket/cpu has fried.
around 200 hours with heat up/cool down phases i believe. +1 for the IC7D, i got sent a sample from IC and it owns. 1-3 degrees better than TX2 which is 3-5 degrees better than AS5.
NO NEED TO WORRY
just use as prescribed in the manual
dun spill it all over ya mobo
Thanks for the +rep! In my sig I have a tutorial where I actually did use AS5 on my GPU has been good for over a year now no problems
Check it out
One more question:
I have both a tube of AS5 and the 'Arctic Silver-Ceramique'
What would be the best situation to use ceramique rather than the silver?
Edit:
Have you seen this? http://indigo-xtreme.com/about.html
Claims to be better than any thermal interface material available, 2-4C cooler.
Note to OP:
When applying the AS5, I have noticed that putting a small pea-sized glob in the center with a little extending outward (like the line method) performs much better than just the line method.
1 - 20 of 83 Posts
