1 - 4 of 4 Posts
Hello
Since the 390.xx drivers, during the boot, between the end of the POST and the Windows loading page, I have artifacts on the screen (very quickly)
No problem with the 388.71
it would seem that it was not an isolated case, possible to solve this "problem", even if it is not very serious ?
Thanks
Totally Tubular
Unless you have problems during normal use there is no issue. The artifacts are likely a byproduct of the transition between BIOS control and Windows control. Maybe the new driver version does that transition differently.
If you're really concerned about it, revert to the older drivers. If they were working fine, there was no need to upgrade anyway.
Discussion Starter #4
OK, thanks ;)
I tested with the stress test of Aida64 and no worries
I returned with the old drivers, no problem with them (although with the 390.xx, I did not see any problem except the artifacts during boot)
1 - 4 of 4 Posts
