Originally Posted by -=*HERO*=-
um, im at work now so, when i get home i'll figure out how far i can take it temp wise. why it that the only game to oc for?
Well all of the other games you listed above your system should handle with ease considering quite a few of them make use of all four cores on your CPU and they are all decently optimized titles
GTA IV's just the exception performance wise...even with my 945 clocked up to 3.8Ghz and running my 4870 and 4890 in crossfire the game will still drop in frames constantly...its playable but annoying as hell
If you are only running at 2.2Ghz on your CPU i am sure your framerates are choppy and unplayable quite often
Its cause you are really CPU limited not GPU limited in GTA
GTA just seems to never be satisfied no matter your clocking or hardware
Do you have any performance problems in your other games? everything plays pretty smooth right?
What settings do you run Fallout 3 at (AA/AF) ? Does it run smoothly?
