1 - 4 of 4 Posts
I have a Radeon HD 7950 and over to 1100/1575. Default is 900/1250
How much energy (W) consume more? Can be in percentage.
Would need to know volts, not clocks of your card. Even then it can be tricky as the card wont stay 100% load, and therefore highest voltages, all the time. Just pick up a kill-a-watt meter and plug it into your wall, then plug computer into that. Measure at stock and your OC. That will give you a real accurate measurement, which you can then check while gaming, idle and basic use, as your power consumption will vary depending on your tasks.
High Clocker
Kill-A-Watt is the only way to tell.
But for reference sake on my old 8350 with 7970 CF.
8350 @ 5ghz
Both GPUs at stock.
650W from the wall during 3dmark 11 (peak)
Both GPUs at 1300mhz/1500mhz with 1.3V
920W from the wall during 3dmark 11 (peak)
So there was a 270W gain overclocking the gfx cards.
135W extra per card.
Normal gaming that would probably be closer to 100W per card.
Your overclock is a lot less so im guessing be more like 50W extra usage with a slight voltage bump, if your pumping 1.3V into it then it might be more like 60W
1 - 4 of 4 Posts
