I'm debating this as I'm about to assemble my machine tonight and figured I'd ask for a little extra advice before I proceed.
I just purchased a AMD 2600 and this heatsink so I was curious if I should just leave the tape that's on there, mount it and be done or should I run to the store and grab some AS5 and mount it that way?
I'm just a little concerned about going the AS5 way because I'd need to properly remove the tape and properly apply the paste. Just want to make sure I do it right because I haven't used the paste before and I've never had to remove tape off a heatsink either.
Any suggestions or tips?
Thanks in advance
Thanks in advance
