1 - 6 of 6 Posts
Okay I just purchased a case. Aspire X-plorer case <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811144102" target="_blank">http://www.newegg.com/Product/Produc...82E16811144102</a><br />
<br />
I also have for my motherboard a Asus A8N deluxe mother board with a X2 4400 cpu OEM. Now my question is im planning to buy the Zalman CPU cooler like this <br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835118223" target="_blank">http://www.newegg.com/Product/Produc...82E16835118223</a><br />
<br />
Now im wondering if the CPU cooler will fit in my case with no problems? <br />
<br />
Thanks
I checked the dimentions on your case compared to mine and they are really close. I have a boat of a cooler and it fits just fine <i>with</i> a fan on the inside window. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
<br />
edit: actually they are the same size <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
So is its okay the Zalman CPU LED fan will fit perfectly in my case then..?
I have the Zalman 9500, my case has a similar depth to the one you have indicated and I don't see why it shouldn't fit. It's really not that huge. Just looks and acts like it.<br><br>
If you are really concerned, wait until your case arrives and then measure the depth available. There is a guide on the Zalman website that indicates the clearances required.
Discussion Starter #5
oh okay thanks
CPU cooler more than case...lol<br><br>
yeah it'll fit fine, they wouldn't make it if it didnt! Although I'd take a different cooler, like a scythe infinity. Cheaper/better looking/better performance!
1 - 6 of 6 Posts
