1 - 11 of 11 Posts
Hi, I'm new here.
I've a problem with my mobo; I can't find any vmod for my asrock 775dual-880pro. Sts vcore is too small... The Cpu run now at 20x157 1.3V.
have anyone know a vcore and vmem mod for my mobo??
sorry about my poor english.
Thanks
Administrator
I have this particular Board but in a 478 socket format and to my knowledge i havent heard a Volt mod for it. I know there are vot mods you can do to the CPU to give it more voltage..Look in the volt mods section in the forum. Also can you please fill out your system Specs in the user control panel as this helps us to help you.
I cant find any volt mod
maybe there is a chance with similiar mobo with the same regulator??
I've tried with m037 performance bios, but better score I get with p1.30 bios...
Administrator
Perhaps theres not a Volt mod for this board Perhaps the Cpu yes..Check in the Volt mod section for a CPU volt mod..but they can be tricky and dangerous.
Discussion Starter #5
what do You mean?? something like pin-mod??on 775??
I've searched everywhere without any results
I'll check the regulators on teh mobo, and then try to solve the problem
Hi,
i`m new here as well.
I have the same mobo as you: Asrock P4Dual-880Pro.
It`s a nice mobo, but my sytems often crashes during gameplay. For example when i`m playing; Need for Speed Most Wanted.
Does this happen to you as well?
Maybe you can help me out here, maybe you`ve got a solution for this problem?
These are my system specs:
Mobo: Asrock P4Dual-880Pro (Socket 478). Bios V1.4
Cpu: Intel Pentium 4 2.4 GHZ
Video: Sapphire ATI X800GTO Pci-E x4
Catalyst driver: V6.2
Memory: 1024mb (dual channel)
Sound: Audigy 2
Hdd: Maxtor 80GB 7200RPM
O\\S: Winxp sp2
I hope you can help me out with this issue.
Grtz.
Discussion Starter #7
maybe too high overclock??what vcore have you got??
tell us sth more about you config
Administrator
Originally Posted by Zetecpower
Hi,
Sound: Audigy 2
O\\S: Winxp sp2
Grtz.
Well i have this motherboard as you know with the most cureent bios being the V1.4 and i have no problems at all . I f your overclocked then its not stable and you may want to find a new stable overclock for yourself also make sure its not a driver issue get the newest ones also re-install them but alos make sure your Cpu isnt getting to hot.
It's always a crapshoot with overclocking motherboards that do not have a pci lock. Some state a working pci lock but seldom are they fully robust and when gaming often you will experience lockups if this is the case.
The easiest way to test is to remove the overclock and play the games again. If you do not repeat these errors then the problem is the overclock/cooling/inability to raise vcore/pci lock not working etc.
It is best to pay the few dollars extra to buy an overclocking friendly board than to purchase a value board that is not overclocking friendly and spend the time hassle with trying to get it stable.
R
Administrator
R
This may actually be the problem I havent done all that much ocing with my current board so i wouldnt know about the PCI locks as such ...May have to ask elsewhere for that info.
Hi,
Thnx for your reaction, but overclocking is not the case.
I mean if I had overclocked my computer, I would have known what the issue was, but I haven`t overclocked it at all.
I`m using the latest drivers wich are available.
I`m thinkig more and more of a conflict between my mobo and my videocard....
These are my updated system specs:
Mobo: ASROCK P4-880Dual PRO (Bios V1.4)
CPU: Intel P4 533MhZ (standard cooling)
Memory: 2x Corsair 512Mb (non-ecc)
VGA: Sapphire ATI X800GTO PCI-e 256mb (with Catalyst 6.2, with standard cooling and not beeing overclocked)
Sound: SB Audigy 2 with the latest drivers
HDD: Maxtor 80 GB IDE 133 (my other drive has crashed
PSU: Q-Tec 400Watts
Monitor: Samsung TFT Syncmaster 730BF
DirectX: 9c
OS: Win XP SP2
Desktop: Logitech LX 700 Mouse and Keyboard.
Well I hope somebody can help me out here,
1 - 11 of 11 Posts
