1 - 6 of 6 Posts
im going to be doing the vmod towmorow so that i can get a vcore of 1.55v instead of 1.45v. I am hoping for 2.5/2.6 but anything more than what i have now is an improvment i have mine rock stable on prime at
vcore = 1.45/ cool and quiet off
htt nb = 800mhz 4x sb 1000mhz 5x
ht = 235
memory = 195mhz (166) 2,4,4,10 timings
vdim = high (2.7v)
multi = 10x
so a overall of 2.35ghz and my memory is at 195mhz but can go to 120mhz at 3,3,3,10 ill will post my new setting towmorow when i do
has any one got the same set up what settings have u got and what bios are u using im using 1.20
i have a problem with my bios i cant go anyhigher than 245ht or it wont post will the ocbeta 1 bios be able to get around 270 ??? help :withstupi
Discussion Starter · #2 ·
well i have done the vomod the pc starts up and i get 1.55v and slightly over but i cant get my pc stable when i put the 1.55v on i tryed 2.4ghz everything on auto and it failed with erros
so i put it to 2.35ghz and it failed even though it doesnt fail at a vcore of 1.45v
need help should i use ocworckbench beta bios 1 instead od 1.20 help!!!!!!!!!!!!!!!!!!!!!
yeah!!! i got it to work i ran it at 2.45ghz on prime for 2 hours and a bit stable temps didnt go over 41c so im happy im yousing 1.2 bios and i cant get beyound 250ht so im puting in ocbeta 1 towmorow im so happy
Ya the beta bios are usually a little more letting on hTT speeds. But 1.2 should be solid up to 274htt. Weird. Just make sure to use dividers right if you are using them, and move your way up slow.
Good luck
i cant get it by 247ht
im using a 166div
and 800mhz and 800mhz 4x.,4x 16bit .16bit
pc is rock stable at 2.45ghz
should i put in the beta bios and what one ??
Discussion Starter · #6 ·
finally i got 2.5ghz stable on occt and prime
after installing ocwbeta1 and the vmod
but i cant go higher miby slightly but 2.5ghz is good for me
better than my orignal 2.35ghz what do u think ?? and i can go to higher ht'sthan before should i try lowering my multi to say 9x and up the ht and see how far the ht can go ??
1 - 6 of 6 Posts
