ASRock 939Dual-SATA2 Corsair XMS Memory Issue.
558 Views 6 Replies 4 Participants Last post by  Justshoe
I have recently ran into some issues running MemTest86, it got to test #8 and it would either get a few errors, freeze, or crash and repost. After experiementing and researching I have found these results.
You have to manually set your timings to 2/2.5-3-3-6 @ 2T. If you do not do this you will not only freeze or crash on test #8, you will have stability problems in windows as well.
Not thrilled to have to set my memory to 2T, but it is only a 5% reduction in performance. Ironically the Corsair XMS Memory line is the recommended memory for ASRock motherboards. Go figure.
Still trying to work the bugs out, and just want to keep everyone posted that has this Motherboard is considering buying it. Word is ASRock is actively working on a bios solution to this, so check their drivers often.
1 - 7 of 7 Posts
Even though i have an ASROCK board and i know its not the same as yours i havent un into many problems with RAM as such. But ASROCK are good in releasing bios updates with fixes so i would expect one to come out soon if not make a complaint or suggestion and i may kick them into action about it
Either you have a bad board, or bad memory.
While i had my asrock sata2 uli i had no problems running cas2 1t with my tccd. Maybe you should try some ocworkbench bios' , or revert back to official bios 1.2.
Unfortunate, but this hasn't happened to many. So its gotta be something specific, not an overall thing about that board.
Hmmm what do you mean by ocworkbench bios' .
Umm no, I do not have a bad board and my memory ran Memtest86 for 15 hours straight with no errors. I firmly understand that it may be a problem native to Corsair Memory, thus my title explicitely states Corsair XMS Memory.
Who knows, others may be having this issue with another brand of memory. I used ocwbeta2 bios to push my processor to 2940MHz. My memory needing more voltage holds my stable overclock to 2.5GHz 24/7, so I reverted back to the official bios because there was not an advantage for the settings I am currently running.
I wrote this little "how to" for the bios mods, so I am fully aware of those applications. Thanks for the input.
Well this is not your mem. go do some reading on ocworkbench and you'll find its all in the board and its issues with 1T reguardless of what mem your using. I dont think anyone has found a combo that does 1T stable.
1 - 7 of 7 Posts
