1 - 3 of 3 Posts
Just installed the H110M-DGS/D3, only comes with onboard DVI, only works DVI to DVI, i tried a VGA to DVI converter and no luck anyone else experienced this as well? if so why though?
Cheapest Man On Earth
The manual says it is a DVI-D port which means it only outputs a digital signal. Digital DVI or HDMI would be the only connections you can make without getting an active converter.
thanks
1 - 3 of 3 Posts
