Asrock X370 pro gaming board with Ryzen 5 - Gskill RAM- assistance with XMP profile setttings
404 3
Hello, I have posted about my setup before on this site however can not locate the post and also i have posted on the ASROCK forum as well. the help i was given has not assisted in getting XMP 2.0 profile loaded without windows 10 crashing or becoming unstable.
Post in ASrock forum - language issue hard to understand.
I have tried running it @ 2800mhz and 3200mhz to no avail so i disabled XMP and running @ stock 2133 mhz.
I really want this to work -
here are my specs:
Windows 10 Pro - 22H2 latest featured update - no updates pending.
Asrock X370 gaming pro MB - latest bios version 7.1 - no updates pending.
AMD ryzen 5 2600x - disabled Core boost - ryzen master installed there was an error reported with overheat once i disbled core boost under CRM bus bridge it went away. AMD stock cpu cooler.
Gskill DDR4 3200 (1600mhz) x 2 = 32gb in slot 1B and 2B . open slots 1A and 2A.
intel M2 main C drive - 1tb
Attached CPU z text report -
Bios Images - what to set
in other forum for Asrock i was told to set these settings based off this forum post on OC - Asrock X370 Taichi Overclocking Thread
edit 2022 Aug 15th add screen capture of zentiming and voltages.
in short, must make sure.
1) vddr_SOC = 1.1v
2) cldo_VDDP = 1v
3) vddg_IOD = 1.1v
4) vddg_CCD = 1.1v
A) procODT = 48 ohms for my ram
IOD and CCD is not in my bios ? do i just ignore those?
What steps do i need to take to get this too run or is it just not going to work with the parts i have installed due to compatbility issues. I have saved Default profiles so i can just load the settings again for 2800 and or 3200.
Thank you..
1 - 4 of 4 Posts
Reactions: Sebi
1 - 4 of 4 Posts
