That might not always work. As Dekaohtoura said above: Try HWINFO and check infinity fabric clock. For your system with ram at 3200 Mhz it should be running infinity fabric clock at 1600 Mhz. If it is not showing infinity fabric clock at 1600 Mhz via software then you might want to specify it manually in bios to make sure it's there. This effects the overall performance with AMD systems. It's a pretty important thing to get right.Thanks for the tip! I checked in the bios and Infinity fabric frequency is set to Auto, which according to the help text means 1:1
