1 - 2 of 2 Posts
Hi all,
I have an ASRock Taichi Z370 which has a Realtek ALC1220. On my old motherboards, I used to be able to separate rear and front audio output streams, but can't seem to on this motherboard. On this one, I can get front audio only (if front jack detection is enabled in Realtek HD Manager) or duplication of front and rear (if front jack detection is disabled).
I have tried several different Realtek driver versions including the latest (Realtek high definition audio driver ver:8295_FF00) from ASRock as well as R2.82 from Realtek's website.
Does anyone have a working driver version that accomplishes separating front and rear audio?
There also seems to be an option missing in this version of the Realtek HD Manager to achieve this.
Discussion Starter #2
Hi all,
There are hundreds of threads online about this issue across several motherboards. I esolved this by simply uninstalling the Realtek software and allowing Windows 10 to handle the drivers. I now see two separate output devices (front and rear).
Thanks
1 - 2 of 2 Posts
