41 - 46 of 46 Posts
Hey mllrkllr88, I'd be appreciated if you could share complete SS of the BIOS (OC profiles, subtiming formula etc). available.
Hi,
Good to see Z590 OC Formula is going to be released.
There are 2 Asmedia Sata ports - Other boards like Maximus XIII Hero don't have this. - Will it be possible to RAID 0 the Asmedia ports? - Usually Asmedia Sata ports don't RAID as it is only ports 0-5 that are RAID compatible.
Old School Overclocker !
Hi,
Hi there , is not possible to do Raid 0 on Asmedia sata ports , as you already know this. Only Intel sata ports can do Raid 0 , i have tested myself on my ASRock z590 OC Formula. I hope this clarify this concern.
Kind Regards: Chispy
Reactions: IronAge
Hi all, It's been a while since I've last been actively overclocking (2016) and coming from a 7700k/Z170 combo for my PC.
Thanks to ASrock and Intel, I've been fortunate to play with Z590 OCF and 11900k cpu since yesterday.
At first glance this is the most overkill system I've ever had and tuning the cpu and memory is quite easy on the OCF with all of the built-in profiles.
If you've had other OCF motherboards in the past, the menus on the Z590 are as easy to navigate and follow a similar format to older gen OCF.
Here are the specs I'm using for these preliminary testing:
-ASRock Z590 OCF
-Intel i9 11900k
-Crucial 3200 cl16 64gb kit (2x32gb)
-EVGA 3090 FTW3 Ultra
-Noctua NH-D15 Air cooler
-Antec 1300W Platinum HCP
-Samsung 980 250gb M.2
-1440p @ 165Hz 27inch G-sync monitor
The manual OC 11900K was set at 5.1ghz @ 1.36v and memory at 4000mhz CL16 @ 1.55V (3200 XMP profile and increased frequency at 4000mhz manually)
GPU Kept at stock settings for all tests.
In summary: Cinebench received a nice boost form manual OC (about 8%) while for gaming the 11900k is already very strong at stock settings and adding a manual cpu and memory OC only added maybe 1-2% in gaming performance.
2489163
2489164
2489165
2489166
Bench Results:
Cinebench R20 Stock - Peak system power draw 315W
2489167
Cinebench R20 with Manual OC - Peak system power draw 390W
2489168
Cyberpunk 2077 Stock - Peak system power draw 595W
2489169
Cyberpunk 2077 with Manual OC - Peak system power draw 660W
2489170
Assassin's Creed Valhalla Stock - Peak system power draw 515W
2489171
Assassin's Creed Valhalla with Manual OC- Peak system power draw 545W
2489172
Counter Strike Source Stock - Peak system power draw 245W
2489173
Counter Strike Source with Manual OC - Peak system power draw 260W
2489174
41 - 46 of 46 Posts
