1 - 15 of 15 Posts
is this mobo:<br><br><a href="http://www.komplett.ie/k/ki.asp?sku=324658" target="_blank">http://www.komplett.ie/k/ki.asp?sku=324658</a><br><br>
Worth it or should i get something better?
Get something better. VIA chipsets are not worth the money.
ok, ill try stretch to this:<br><br><a href="http://www.komplett.ie/k/ki.asp?sku=322039" target="_blank">http://www.komplett.ie/k/ki.asp?sku=322039</a><br><br>
how does it look?
Ahh....much better. I believe that board is a bit picky about RAM though, so read up on it a bit. That is a heck of a lot better than the ASROCK VIA board.<br><br>
Edit: Which AM2 CPU are you getting?
Why not get my current motherboard, its amazing and very cheap aswell - its £70 new I think.<br><br>
I will have a look on the site for you <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"><br><br>
EDIT: Its a AM2 Woopsies <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"><br><br>
I will look for others<br><br><a href="http://www.komplett.ie/k/ki.asp?sku=322111" target="_blank">http://www.komplett.ie/k/ki.asp?sku=322111</a> This is also a great board <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #6
<div>Originally Posted by <strong>bdattilo</strong></div>
<div style="font-style:italic;">Ahh....much better. I believe that board is a bit picky about RAM though, so read up on it a bit. That is a heck of a lot better than the ASROCK VIA board.</div>
</td>
</tr></table></div>
Yea i will, i was looking at the asrock cos of the price, i would love the fatal1ty abit, but i dont think i can afford 200 on just the mobo ya know.
Discussion Starter #7
<div>Originally Posted by <strong>Mad_Handlez89</strong></div>
<div style="font-style:italic;">Why not get my current motherboard, its amazing and very cheap aswell - its £70 new I think.<br><br>
I will look for others</div>
</td>
</tr></table></div>
Thx
404 Title Not Found
VIA isn't the best, but they're pretty reliable and if you don't plan on OCing you should be ok. The nforce chipsets may provide more OC/stability. I'd suggest you go with what your needs are, cheap/stock, via would be ok.
Discussion Starter #9
<div style="font-style:italic;"><a href="http://www.komplett.ie/k/ki.asp?sku=322111" target="_blank">http://www.komplett.ie/k/ki.asp?sku=322111</a> This is also a great board <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"></div>
</td>
</tr></table></div>
Yea that is nice so what you think,<br><br>
Abit<br><a href="http://www.komplett.ie/k/ki.asp?sku=322039" target="_blank">http://www.komplett.ie/k/ki.asp?sku=322039</a><br><br>
or Gigabyte<br><a href="http://www.komplett.ie/k/ki.asp?sku=322111" target="_blank">http://www.komplett.ie/k/ki.asp?sku=322111</a>
<div>Originally Posted by <strong>accskyman</strong></div>
<div style="font-style:italic;">VIA isn't the best, but they're pretty reliable and if you don't plan on OCing you should be ok. The nforce chipsets may provide more OC/stability. I'd suggest you go with what your needs are, cheap/stock, via would be ok.</div>
</td>
</tr></table></div>
Yeah my old ECS Board had a via chipset and I coulnt get past 2.2Ghz on my Venice 3000+ with clockgen cause of the crappy bios.<br><br>
I got my new DFI lanparty with the Nforce4Ultra Chipset and I got it to boot at 2.8Ghz Stable 2.6Ghz <img alt="" class="inlineimg" src="/images/smilies/gunner2.gif" style="border:0px solid;" title="Gunner2"><br><br>
Via chipsets are fine for EVERYTHING except overclocking <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br><div style="margin:20px;margin-top:5px;">
<div>Originally Posted by <strong>thedarklordjay</strong></div>
<div style="font-style:italic;">Yea that is nice so what you think,<br><br>
or Gigabyte<br><a href="http://www.komplett.ie/k/ki.asp?sku=322111" target="_blank">http://www.komplett.ie/k/ki.asp?sku=322111</a></div>
</td>
</tr></table></div>
The only difference in those boards are that the Gigabyte has a better Audio Solution - Same chipset and processor compatiblity - Its just preference but I have a look at some reviews for you cause im bored <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #11
<div style="font-style:italic;">Yeah my old ECS Board had a via chipset and I coulnt get past 2.2Ghz on my Venice 3000+ with clockgen cause of the crappy bios.<br><br>
Via chipsets are fine for EVERYTHING except overclocking <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br><br><br>
The only difference in those boards are that the Gigabyte has a better Audio Solution - Same chipset and processor compatiblity - Its just preference but I have a look at some reviews for you cause im bored <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"></div>
</td>
</tr></table></div>
Well put the audio out of the window, cos ill be using my pci sound card.
<b>Abit K8N Sli - Hexus.net Thoughts<br><br></b>
<div class="smallfont" style="margin-bottom:2px;"><b>Quote:</b></div>
<table border="0" cellpadding="6" cellspacing="0" width="99%"><tr><td class="alt2" style="border:1px inset;">abit's KN9 SLI ran a 9-hour burn-in test in our labs without any trouble, along with a further barrage of tests and burn-ins under different configurations. However, we are somewhat concerned with its POSTing issues with DDR2-800 RAM and USB devices, along with the possibly related USB performance. abit have indicated it's related to specific RAM modules, so watch out for compatability in the meantime. We'll bring you more information related to this issue if and when we get it.<br><br>
Once again we run into nForce 570 SLI and NVIDIA 90-series driver issues in SLI. It's a bit of a let down for board makers using this chipset to see that their performance gaming boards can't make use of the latest drivers yet. The same is true of nTune. These compatibility issues don't just hang over this sole board, however.<br><br>
On to the good stuff, then. This board has a great layout. Once again abit shows a great deal of care in positioning headers in both useful and accessible locations.<br><br>
Performance of this board, barring USB, is excellent. We've shown how the cheaper nForce 570 SLI chipset can hold its own against its bigger brother. Add to this the fact that abit's board has a good number of BIOS options for tweaking, trumping MSI's K9N SLI Platinum. Nevertheless, there could still be more. The question is whether somebody deliver it with this chipset or not?<br><br>
If silent cooling is your thing, then abit's got it covered with its Silent OTES solution. As we've already highlighted, however, take care that there's enough airflow for the chipset to be kept cool and operational.<br><br>
What abit has here is the grounds for a very appealing board. While there do seem to be some compatability issues to iron out, we hope abit can fix these to boost its appeal further. Regardless of this, however, the abit KN9 SLI presents itself as a very cheap nForce 570 SLI solution and it's that which gives it it's ultimate appeal. It's not a perfect board, then, but it's value still makes it well worth considering.</td>
</tr></table></div>
<b>Thoughts on Gigabyte - Oc Workbench.com<br></b>
<table border="0" cellpadding="6" cellspacing="0" width="99%"><tr><td class="alt2" style="border:1px inset;">Pros<br><br>
* SATA II (NCQ)<br>
* HD Audio<br>
* Dual BIOS<br>
* 1394<br><br>
Cons<br><br>
* No Wifi<br>
* Single GBe<br><br>
Performance 10 / 10<br>
Features 7 / 10<br>
Ease Of Installation 9 / 10<br>
Overclocking Features 9 / 10<br>
Documentation 8 / 10<br>
Packaging 8 / 10<br>
Overall Rating : 8.5 / 10</td>
</tr></table></div>
<br><br>
It seem as if the ABit is a much more popular board and in benchmarks top out its mid priced boards. So I would go with that As the Gigabyte only had been reviewed by one site and I saw a few compatiblity issues with RAID and certain X2's <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Discussion Starter #13
nice, i think thats all the info i need. I'll try and decide ah i've got till December to finalize what i want in january. So im ok. Just wanna get a headstart on it. Thx for the info. +rep
<div style="font-style:italic;">nice, i think thats all the info i need. I'll try and decide ah i've got till December to finalize what i want in january. So im ok. Just wanna get a headstart on it. Thx for the info. +rep</div>
</td>
</tr></table></div>
No problem mate - That what im here for <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
If your anything like me you will change your mind by Jan and want a C2D System or a Quad Core <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"><img alt="" class="inlineimg" src="/images/smilies/gunner2.gif" style="border:0px solid;" title="Gunner2">
Discussion Starter #15
<div style="font-style:italic;">No problem mate - That what im here for <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
If your anything like me you will change your mind by Jan and want a C2D System or a Quad Core <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"><img alt="" class="inlineimg" src="/images/smilies/gunner2.gif" style="border:0px solid;" title="Gunner2"></div>
</td>
</tr></table></div>
Haha even if my mind changes i doubt my budget will, lol
1 - 15 of 15 Posts
