Asrock's new $100+ gem - 970 Extreme4
18896 74
http://www.newegg.com/Product/Produc...82E16813157262
And here comes Asrock's efforts in bringing Bulldozer to the budget users, too bad the BD CPUs are still only in the AMD factory.
ASRock AMD 9 Series Zone
ASRock > Products > 970 Extreme4
ASRock Dura Cap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
Supports AM3+ Processor, 8-Core CPU
Supports Dual Channel DDR3 2100(OC)
Supports AMD Quad CrossFireXâ„¢ , 3-Way CrossFireXâ„¢ and CrossFireXâ„¢ *
Supports NVIDIA® SLI™ *
4 x USB 3.0, 5 x SATA3, 2 x IEEE 1394, Dr. Debug, Power/Reset/Clear CMOS Switch with LED
7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec), Supports THX TruStudioâ„¢
Supports XFast USB Technology, Graphical UEFI
Supports On/Off Play, Instant Boot, Instant Flash, APP Charger, SmartView, Turbo UCC
*3 x PCI Express 2.0 x16 slots (PCIE2/PCIE4: single at x16 (PCIE2) / x8 (PCIE4), or dual at x8 (PCIE2) / x8 (PCIE4) ; PCIE5: x4 mode)
ASRock 970 Extreme4 Specs
And here comes my simple PnS photos.
BOX
BUNDLED GOODIES
MOBO
- Note the nVidia SLI certified screen printed label in addition to the usual ATI CrossfireX one
BRANDING, HEATSINKS, BUTTONS AND DEBUG LED
THRONE OF POWER
- 3 fan headers sitting pretty in a row
STORAGE & FRONT USB3
UEFI screenshots
- sprinkling of F12 screenie captures
Test rig
Phenom II x2 560 unlocked to x3 at 3.8GHz [email protected] (good cores are 0, 2, 3 while core 1 is bad)
Antec Kuhler 620, push pull fan config
2 x 4GB [email protected]
HIS HD 6950 unlocked shaders
Enermax NAXN 850W PSU
Prime95 Blend
- short run to check stability esp. core unlocking and CPU-NB o'c
3DMark11 P Scores
see below for SLI scores
Temperature Readings of Heatsinks
- measured during Prime95 Blend run, had to use a cheapo IR gun for now as none of the HW Monitor readings corresponded to CPU temps.
unlocked [email protected] CPU IHS 42C
Kuhler 620 Radiator 40C
Mosfet 47C
Southbridge 40C
RAM 40C
Update
- after trying out a few utilities, finally found that the present version of HWInfo32 does the job very well of reading the onboard sensors of this mobo and yet does not deactivate CnQ. Pity it still does not read the vCPU-NB but otherwise, it's great cos it is freeware and has a systray display feature too (the green boxed icon in the screenie below).
S3 Sleep & Resume
- is a-OK even when overclocked!
Notes: Present UEFI P1.10 needs some more polishing esp. with vCPU-NB (overvolts) and core unlocking. CnQ is disabled once the CD bundled AXTU is installed and run (need to uninstall AXTU to restore CnQ).
More to come...
Reactions: Tyreal and Redwoodz
1 - 20 of 75 Posts
iPuppet
Intel/Nvidia
Wow, very nice. But I am still considering the Sabertooth 990FX.
iPuppet
Take the CHV instead if you really want Asus, I have tested both the Asus models too and the Sabretooth is definitely not as polished.
iPuppet
Discussion Starter · #9 ·
This one is cheap and quite awesome so far, just that it isn't too good with non-BE CPUs yet due to it being so new and its UEFI still needing some polishing. Somehow I love 'underdog' brands/models esp. a surprise hit like this which comes with an unbelievably solid balance of cost, features and performance.
If I can just find some time to pop in my 1090T, I may be more able to tell you how it may run with your 1100T. I have only tried it out with a [email protected], 970BE and 1055T. Still got my [email protected] and 1090T to go... if I don't get distracted by the next new toy.
alright..do it baby..lol
ummmmm
very good review
one question, can you control Sys_fan header's speed with a 3th party software (like SpeedFan maybe)
im considering ASrock to the new build (when BD comes) but it is very important for me have control to 3 fan headers (plus CPU_fan of course)
thankyou very much!
Very nice results!
Intel/Nvidia
Could you elaborate on your term "polished"? I read the Sabertooth member club here and many reviews saying this is an excellent board. Has every feature that the Crosshair V have, except for the buttons and the expander to do 4-way SLI, but I am never going to use more than 2 anyways.
Head Smeghead of OCN
..... Has every feature that the Crosshair V have, except for the buttons and the expander to do 4-way SLI, but I am never going to use more than 2 anyways.
Actually the CHV can only do Tri-SLI, not a quad SLI/Crossfire setup - At least that's how this one is as purchased.
I did pull the trigger on the CHV and so far it's been a good board, quirky but good.
ASRock does make some of the best hardware for the $$'s spent and I do have one or two around here that's been nothing but great so far. In fact some ASRock boards are near or even at the top of their class for performace, reliability and cost.
I think they mean quad-SLI in this board as in two dual GPUs
iPuppet
Discussion Starter · #18 ·
This post is for the potential mobo upgraders who are still holding on to their old chipset/mobos undecided.
Checking out the unlocking of the older revision C2 CPUs
... and yup, it works. Using the latest P1.20 UEFI release which is still slightly quirky with core unlocking, HTT clocking and CPU-NB overvolting but no matter, it does work after a few tries to string the UEFI settings all together.
My old hot running Phenom II 550BE (VID 1.35V iirc) being put back into service, running overclocked at 3.5 GHz, NB2600 cores unlocked successfully.
HTH
1 - 20 of 75 Posts
