Hi guys,
I own a pair for Astro A40 2013 with mixamp.
The mixamp is updated to the latest firmware.
The mixamp is connected to my computer via optical cable on a Dolby digital live capable sound card (AuzenTech X-PLOSION Cinema 7.1 Sound Card)
There is also a usb cable plug to the pc for voice communication and set so in Windows (replaced with a ps3 remote charger cable due to power cutting off with the oem wire. it's a common issue.)
The setup works fine except I get very poor Mic sound quality.
The problem:
The mic sounds awful. The volume spikes and is all distorted. I try every option possible but I can't get it to work and it's getting worst and worst.
I already had to change one mic on warranty because it stopped working at all.
I'm looking for a none-Astro brand boom mic I could plug there.
I checked and found one from Tritton and one from Turtle Beach that could be good.
My main concern is the Astro A40 mic pinout.
http://www.kitguru.net/wp-content/up...10/micjack.jpg
compare to the turtle beach and tritton
http://www.pcgameware.co.uk/images/T...microphone.jpg
http://www.hardwareheaven.com/review...eadset_mic.jpg
Do you guys know any mic that would fit in my headphone?
I would also like to find the Astro A40 mic pinout.
Thank you in advance
The problem:
