1 - 20 of 66 Posts
AMD 5900X, MSI 570X Unify, GTX1080, F4-3600C16D-32GTZN
Discussion Starter · #1 · (Edited)
Bios mod Asus 470x-F
Currently modded:
  • Unlocked CBS menu
  • Unlocked VDDP in AI tweaker
  • Spread Spectrum disable option AI tweaker
  • Fan Stop options in monitor
  • Some CPU features unlocked
  • Also modded the 1000/2000 side of the bios so everyone can have some fun.
Two months ago I decided to learn some things about modding my bios. After a lot of testing I've decided to share this with you guys. Now I know the basics I want to learn more in the future. Let me know if you're missing something, have some modding advice and the experiences you have with this mod.
Use at your own risk, I'm not responsible for any problems. Don't modify options you don't know.
You need to follow the instructions using Flashrom here https://www.overclock.net/forum/11-amd-motherboards/1733304-agesa-fw-stack-patched-bioses-3rd-gen.html especially this post https://www.overclock.net/forum/28128500-post4.html. After making a backup of your bios use FD44Editor to copy your serial number etc. to the new bios https://www.overclock.net/forum/28139368-post274.html.
Don't forget to edit your own UUID, MAC and Motherboard S/N before flashing with flashrom
Download Asus 470-F 5406 mod here: https://drive.google.com/file/d/1OIBeq866lFpaUUz190himkSI53iOQLSU/view?usp=sharing
Recomendations:
Bios guide from Verangry on ComputerBase, all the settings are available now (German, use google translate if needed). Nice community!
When I use MBIST I get wierd errors so be careful with that.
Advanced settings from Dram Calc, also shown on one of the screenshot (memory training)
I hear a lot of people complaining about Asus removing AMD Cool&Quiet. It's not removed, it's enabled by default and has a different name. Don't worry about it.
hey there. is it possible to stop PWM fans with your mod if reading temperatures are low? it's so lame that the original bios can stop only DC fans.
ps.
btw, it would be great if you add an ability to create a custom curve for CPU_OPT fan, if I remember its name correctly. one more lame thing from ASUS creating a 4-pin controller and no actual control for it.
Yes it's possible. I only tried the option for a couple of minutes so be shur to so some testing! Let me know if it works well!
good thing for overclocking. my CPU was totally unstable with Spread Spectrum enabled. however, I cannot imagine a decent overclocker flashing his bios and using auto OC at the same time :)
I'll probably check the next version with the CPU_OPT control implemented. It would be great if you edit your first post adding screenshots from bios and explaining the exact features you've unlocked (best if examples of usage included). thanks for doing it, good well-round mobo.
"Topfn"
Hey Eder,
you modded/enabled a few more things than sexysale and myself back then. Nice!
Would you be so kind to post some screenshots of those additional settings?
Greetings
Hey Eder,
Greetings
When @The Stilt released the modified Flashrom and you guys came with the Spread Spectrum mod it inspired me to learn some bios modding so thank you! :thumb:
I've added some screenshot.
Discussion Starter · #8 ·
Ha! I'm currently using auto OC, my 3700x boosts to 4450. I want to try some CCX overclock. If only we had some decent bios options for that (investigating).
Ok about CPU_OPT. I found that just like AIO_PUMP/W_PUMP+ all the settings are coupled. I don't know if it's possible to separate them. I'm currently learning about modifying menu's so I don't think I'm skilled enough to tackle this issue (yet). Example below.
0x496D0 Numeric: CPU Fan Middle. Duty Cycle (%), VarStoreInfo (VarOffset/VarName): 0xD, VarStore: 0x1D, QuestionId: 0x27A7, Size: 1, Min: 0x14, Max 0x64, Step: 0x1 {07 91 D6 0A D7 0A A7 27 1D 00 0D 00 04 10 14 64 01}
0x496E1 Default: DefaultId: 0x0, Value (8 bit): 0x14 {5B 06 00 00 00 14}
0x496E7 End {29 02}
0x496E9 End If {29 02}
0x496EB Suppress If {0A 82}
0x496ED QuestionId: 0x27A0 equals value 0x3 {12 86 A0 27 03 00}
0x496F3 Not {17 02}
0x496F5 QuestionId: 0x279D equals value 0x0 {12 06 9D 27 00 00}
0x496FB Or {16 02}
0x496FD QuestionId: 0x279D equals value 0x2 {12 06 9D 27 02 00}
0x49703 Not {17 02}
0x49705 QuestionId: 0x39C equals value 0x1 {12 06 9C 03 01 00}
0x4970B Not {17 02}
0x4970D QuestionId: 0x279D equals value 0x1 {12 06 9D 27 01 00}
0x49713 Not {17 02}
0x49715 Or {16 02}
0x49717 And {15 02}
0x49719 Or {16 02}
0x4971B End {29 02}
0x4971D Numeric: CPU Fan Middle. Duty Cycle (%), VarStoreInfo (VarOffset/VarName): 0xE, VarStore: 0x1D, QuestionId: 0x27A8, Size: 1, Min: 0x3C, Max 0x64, Step: 0x1 {07 91 D6 0A D7 0A A8 27 1D 00 0E 00 04 10 3C 64 01}
0x4972E Default: DefaultId: 0x0, Value (8 bit): 0x3C {5B 06 00 00 00 3C}
0x49734 End {29 02}
0x49736 End If {29 02}
0x49738 Suppress If {0A 82}
0x4973A QuestionId: 0x27A0 equals value 0x3 {12 86 A0 27 03 00}
0x49740 Not {17 02}
0x49742 QuestionId: 0x279D equals value 0x0 {12 06 9D 27 00 00}
0x49748 Or {16 02}
0x4974A QuestionId: 0x279D equals value 0x3 {12 06 9D 27 03 00}
0x49750 Not {17 02}
0x49752 QuestionId: 0x39C equals value 0x0 {12 06 9C 03 00 00}
0x49758 Not {17 02}
0x4975A QuestionId: 0x279D equals value 0x1 {12 06 9D 27 01 00}
0x49760 Not {17 02}
0x49762 Or {16 02}
0x49764 And {15 02}
0x49766 Or {16 02}
0x49768 End {29 02}
well, it's great enough that you've made it possible to stop the PWM fans. I've already sent the request for that to asus support, but they may ignore it easily.
could you please add some short explanations of the unlocked options? best if these explanations would be shown down below in the bios itself, if it's simple enough to do. also do you consider to mod newer versions of bios when they're out?
just flashed mine. so many options, it's insane! as for fans: should I manually set duty cycle to 0% or enabling fan stop option will stop them automatically when temperatures are low enough? was it hidden option or you've made it by yourself?
thanks a lot, this is huge!
Discussion Starter · #12 ·
Awesome - thanks for the screenshots!
So the CPPC preferred cores setting was actually hidden and not a "X570-only" feature? Well, thanks a lot Asus! -.-
Edit:
I flashed it and it's working fine. No issues here.:thumb:
Regarding Cool´n´Quiet...
Source1
Source2 (~1:26:08)
Haha I've read somewhere a vendor put the option back in. Thanks for the feedback! I'm glad everything is working for you.
The Fan Stop option should stop the fans when the temperature is below the Lower Temperature settings. For example when you put 30 in the Lower Temperature the fans stop when a temperature is measured of 29.
thanks for your answer :) one last question though: how can I get into memory training section which can be seen on your screenshot? I cannot find it for some reason, even though I see «DDR4 Common Options».
Discussion Starter · #14 ·
thanks for your answer /forum/images/smilies/smile.gif one last question though: how can I get into memory training section which can be seen on your screenshot? I cannot find it for some reason, even though I see «DDR4 Common Options».
You're close. It's in the Phy Configuration/PMU training.
Hi,
I have a problem with USB 3.1 I'm getting max 20mb/sec where on Intel mainboard is 200mb/s. Is there any USB options in your MOD that can solve speeds on USB 3.1?
Discussion Starter · #18 ·
Hi,
Did you manually install any ASMedia USB driver package?
Try out "pure" 1.16.59.1 Asmedia drivers
I had to manually point windows to the right direction for the correct AMD Sata Controller driver instead of a generic one. Wouldn't surprise me if something simular is happening with the USB drivers.
1 - 20 of 66 Posts
